Wed, Feb 19, 12:48 AM CST
Forum Moderators: RedPhantom
Subject: Help on rendering larger files on Win2K
JimYount ( ) posted Fri, 11 January 2002 at 8:45 PM ยท edited Tue, 04 February 2025 at 3:34 AM
The poser folks and I are struggling with a problem on my machine. It's a loaded Dell Precision Workstation 530, with 512K RAM, and lots of hard drive space. I'm getting the "insufficient disk space" failure to render above about 1K files (anytime I try to render in another window). I've applied the pagefile.sys workaround, with no luck (reducing the minimum to 10MB).
I would really appreciate hearing from anyone who has run into this problem and solved it.
Thanks in advance..
Jim
whoopdat ( ) posted Sat, 12 January 2002 at 2:08 PM
I forget what the error is, but it's not memory related I'm fairly sure. I think it has something to do with a corrupt .obj or .rsr or something. Put that error, or most of it, into a search field in the forum here and I'm sure you'll run into dozens of threads asking the same question and telling you how to fix it.
trine ( ) posted Thu, 17 January 2002 at 8:31 AM
Attached Link: http://www.detaildesign.dk
Well....I had the same problem when trying to render animations of more that 100 frames, I solved it this way. I partitioned my hard drive with Partitiomagic, placed poser as the only application here with about 1GB to run with. I now render away with no problems as long as I don't save any renders or animations in the same drive as poser. Hope this works for you too.
JimYount ( ) posted Thu, 17 January 2002 at 9:39 AM
Thanks for the information! I'll give it a try, and let you know how it works. The Poser folks finally gave up, telling me that I should reinstall windows 2000. Since the machine is a brand new Dell Precision Workstation, and its twin is exhibiting the same problem, I won't go there... Jim
