Wed, Dec 25, 8:57 PM CST
Subject: A search for bodies
buckrogers ( ) posted Sun, 26 December 1999 at 5:46 PM ยท edited Wed, 25 December 2024 at 8:26 PM
In a Poser scene with several models in, how can I select the "body" invisible root segment of any one of those models, so I can easily make the whole of that model bigger or smaller by a set percentage?
Kevin ( ) posted Sun, 26 December 1999 at 5:55 PM
Select the figure from the current figure menu, then select body from the current element menus. Then resize the body using yscale (or whatever). You can rename the figure by selecting the body, then object|properties menu and changing the name from figure 1 to something else.
wyrwulf ( ) posted Sun, 26 December 1999 at 5:58 PM
If I understand what you are asking, just click on the figure in the scene, then at the bottom of the document window, click on the down arrow on the right (current element). Then select Body in the pop up window. This is on page 113 in the P4 manual.
headhunter ( ) posted Mon, 27 December 1999 at 12:40 AM
Hotkey for that is the "2" key. (Top row, not keypad) Select any part of the figure's body & press 2 1 is current element 2 is current figure 3 is current camera I use these shortcuts all the time
Anthony Appleyard ( ) posted Mon, 27 December 1999 at 2:46 AM
Which of these work with Poser 3?
Nance ( ) posted Mon, 27 December 1999 at 8:50 AM
All of them should. Hot Keys: 1=object, 2=body, 3=camera, 4=light. (Watch out - You're gonna kick yourself for missing these :0 )
