Thu, Feb 13, 5:38 AM CST
Subject: Trees
terra-man ( ) posted Fri, 18 January 2002 at 3:37 AM · edited Thu, 13 February 2025 at 5:06 AM
Hi guys,
I was wandering what you uys use too create trees. Do you often use the tree-lab? I've seen some nice tuts on cretaing trees out of a greyscale image and stuff, but branches want be possible that way. I see so manny cool trees in the galleries, and I myselve am not able to create it.
Tips or tuts are really welcome.
Regards,
johannes
ICMgraphics ( ) posted Fri, 18 January 2002 at 4:59 AM
Attached Link: http://http://www.brycetech.com/
Bryce Tech has a pretty good tut on trees. Also in Bryce 5 (not sure if this works in other vers) When you choose to create a tree in bryce, hold the alt key and a small explorer will pop up with some very nice pre made trees. There are not alot of them, but enough to give you a good start so you can learn from them. hope this helps ICM
tmac87 ( ) posted Fri, 18 January 2002 at 7:31 AM
Mine must be broken, can't seem to get the explorer to open...
the3dwizard ( ) posted Fri, 18 January 2002 at 8:09 AM
I think it only works if you have applied the 5.01 patch which you can get at corel.com.
