Sun, Dec 22, 11:33 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 20 7:20 am)
Subject: Mesh smoothing when importing OBJ?
nerd ( ) posted Sun, 26 December 1999 at 4:43 PM ยท edited Sun, 22 December 2024 at 11:19 AM
Forum Moderator
When importing an obj poser automatically smoothes the mesh. What if I don's want the mesh smoothed. I want sharp corners! Where do I poke poser to get sharp edges?
Kevin ( ) posted Sun, 26 December 1999 at 6:29 PM
It used to be that 3DMF didn't get smoothed. Also you could play with the smooting groups in the obj files. I have not really tried this.
JeffH ( ) posted Sun, 26 December 1999 at 7:36 PM
I think you put "s off" after the first group in the OBJ. This only works for custom figure files that are accessed from the geometries directory, and not an imported OBJ.
Jim Burton ( ) posted Sun, 26 December 1999 at 8:53 PM
Nerd- The only solution I know is to subdivide the mesh close to the corner you want sharp. Sort of a real pain, if you do it (the subdividing) in RDS5 it will make a whole lot of semi-bad polygons too, at no extra charge.
PhilC ( ) posted Mon, 27 December 1999 at 12:43 AM
To amplify Nurds reply:- I use a very small bevel on the edges of the planes that I want to look flat. Regards PhilC
Anthony Appleyard ( ) posted Mon, 27 December 1999 at 2:59 AM
When I was writing my RSR2OBJ utility, I found that putting s on and s off in the .OBJ file seemed to make no difference in the resulting mesh .RSR file.
nerd ( ) posted Mon, 27 December 1999 at 3:06 AM
Forum Moderator
PhilC, Let me get this. Put in an extra row of faces (real small) They will "absorb" the smooth and leave me with a sharp edge.
Kevin ( ) posted Mon, 27 December 1999 at 10:42 PM
Have you looked at importing the object as 3dmf? Last time I tried (poser 3) it didn't smooth at all. This may have been fixed, but I don't rember any mention of changes to it.
nerd ( ) posted Mon, 27 December 1999 at 11:07 PM
Forum Moderator
What I ended up doing was this, incase any body has the same trouble. In the 3D editor i seperated the mesh at the edge into two groups. Then imported it into poser. Then I used the grouping tool to put it back together and spawned a prop. Sharp edges. Geez what a pain!
