Fri, Nov 22, 8:23 PM CST
Subject: Pure thing...
Kinouk ( ) posted Fri, 18 January 2002 at 10:33 PM ยท edited Sun, 04 August 2024 at 5:53 AM
she needs eye lashes.. as you can see the eyelash trans is there.But when I render, no lashes. I must be missing something in the settings!
Little_Dragon ( ) posted Fri, 18 January 2002 at 10:44 PM
You've applied the transparency map for the eyelashes, I assume? What are your eyelashes' Transparency Min and Max settings on the Surface Materials panel?
Kinouk ( ) posted Fri, 18 January 2002 at 10:53 PM
Hlight 73 Trans mim 100 trans max 100 fall off 0 colors are brn,blk,blk and white
Little_Dragon ( ) posted Fri, 18 January 2002 at 11:03 PM
Ick! Try this: Trans Min = 0% If the minimum transparency is 100%, that makes it completely invisible.
Kinouk ( ) posted Fri, 18 January 2002 at 11:05 PM
This is the transparency I'm using.Only a bigger size.
Kinouk ( ) posted Fri, 18 January 2002 at 11:18 PM
Boy..do I feel dumb;) There are two eyelashes on the pulldown menu. Now she has eye lashes..next is hair. Thank you for your time!
