The redhead is straight on, but rotated. The black woman's was set up in layers (well, actually you have to use layers regardless), then I 'erased' over her face on her right side and cloned quite a bit. The hairstyle, I guess, since it is 'long', was cut off at the bottom and sides so I had to clone there (in some cases I had to clone over their 'poser' hair since I didn't have these images in layers-just in .bmps). The bottom left was simply a case of rotating and cloning just a bit to cover her hair. The bottom right had more hair on the right side in the original hairstyle but, again, was cut off sides and bottom, so I cloned (smudged, pushed also) quite a bit on her left shoulder--had to do some over her forehead also to cover her 'poser' style. I also recolored all of these. In each case the style would work out, but the hair color with the coloration of the models was not good. pa902, look down below at the thread of Tim Laubach's where he did some very VERY nice versions of this hair on his images. The 'hair' comes from the Cosmo Virtual Makeover CDs. There are several versions--the original with alpha channels (which you should be able to find REAL cheap) is the easiest to use. Diane B
I especially like the red head for some reason but their all great... =) Very good Picnic and you have the cloning down better than I.... One thing I like about Istyle is none of the hair images are cut off, even the longer hair.. But unfortunately VM2 has better quality hair in my humble opinion, but Istyle is still good.. A lot of their styles (VM all versions) are cut off and they don't have alpha channel images on their CD except the original pink box version.. Maybe if they see such an interest their product in the Poser community they'll change this in future releases... *crossing fingers ~Cindy
Yes Pa902, it has the wigs on the CD, alpha channels, so like Cosmo Virtual Makeover Original you don't have to install it.. Their wig files are in *.png format... Here is the url http://www.sierra.com/sierrahome/beauty/ I recommend anyone interested in Isytle to have a picture thumbnail viewer like Thumbs plus or or something simular cause there are lots of wigs on the CD to view....ugh! ~Cindy
