Sun, Feb 16, 7:30 PM CST
Subject: Set props to be included with Balro... err, Valarauko
Valandar ( ) posted Tue, 22 January 2002 at 8:50 AM ยท edited Fri, 22 November 2024 at 12:47 PM
I decided to include two set props with my Valarauko (Demon of Fire and Rage)... The Pit, with a stone pit surrounded by an inscribed triancle inside a circle, and The Bridge, a pair of cliffsides with a bridge across...
Remember, kids! Napalm is Nature's Toothpaste!
SAMS3D ( ) posted Tue, 22 January 2002 at 8:52 AM
Very cool. Sharen
cloudedInMystery ( ) posted Tue, 22 January 2002 at 8:59 AM
Think you should stay away from the razor-sharp edges (especially on stone blocks). Probably be good for you to vary the size of the blocks somewhat and add a few rough edges. Also, you probably should model some of the detail into the stone background. The bump map just doesn't do. Not bad.
Valandar ( ) posted Tue, 22 January 2002 at 9:09 AM
Clouded... A:) For Poser, polycount means sharp edges actually work better, because it's problems with higher polycounts. B:) The rock face IS modelled and bumped. For someone who doesn't use Poser, you sure are opinionated about it...
cloudedInMystery ( ) posted Tue, 22 January 2002 at 9:19 AM
I've heard that Poser has problems rendering sharp edges, since it's renderer is designed for organics. You're right, I don't use Poser. My opinions are about your models shown above--not Poser.
Valandar ( ) posted Tue, 22 January 2002 at 9:33 AM
The models are done as they are SPECIFICALLY for the Poser engine. And these models were rendered in Poser.
mwa ( ) posted Tue, 22 January 2002 at 11:04 AM
I think you should be able to smooth the edges a little bit with out adding more poly atleast not that many. I don't know what you working in but in max it shouldn't be a big problem.
mwa ( ) posted Tue, 22 January 2002 at 11:06 AM
Apart from the sharp edges it looks realy good!
Valandar ( ) posted Tue, 22 January 2002 at 11:36 AM
Well, the thing is, these set props are nothing but add-ons and tiny little extras to the actual pack containing the Valarauko... they're not the actual product, itself.
