Fri, Nov 8, 3:35 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 08 12:39 am)
Subject: What's wrong with my shadows?
AliasAngel ( ) posted Fri, 01 February 2002 at 6:38 PM ยท edited Wed, 06 November 2024 at 12:04 PM
I can't get my shadows to look like shadows. What's wrong?
Kiera ( ) posted Fri, 01 February 2002 at 6:42 PM
Looks like you changed your shadow color. Check the color at the bottom right of the document window to make sure you haven't accidentally changed it from the original.
AliasAngel ( ) posted Fri, 01 February 2002 at 7:08 PM
Nope, that's not it. I already checked that.
Little_Dragon ( ) posted Fri, 01 February 2002 at 7:16 PM
Do you have shadows enabled under Render Options in the Render menu?
AliasAngel ( ) posted Fri, 01 February 2002 at 7:26 PM
Well, I finally just closed Poser then opened the file again, and it rendered the shadows just fine. Weird.
hauksdottir ( ) posted Fri, 01 February 2002 at 9:31 PM
If you change the focal length of the camera you are rendering from, you can ameliorate the way the columns appear to lean in (a fish-eye effect). Try setting it to at least 100, but you might have to go even higher to straighten them out. Carolly
AliasAngel ( ) posted Fri, 01 February 2002 at 11:28 PM
Carolly - Thanks for the tip, but that isn't my actual shot. I only used that pic to show the shadow weirdness.
geep ( ) posted Sat, 02 February 2002 at 1:17 AM
... camera set to about 55 is close to what the human eye sees. Less than this value starts looking "fish eyed." More than this value starts to "flatten out." I usually switch between 24 ---> 55 ---> 110 depending on the effect that I want. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Routledge ( ) posted Sat, 02 February 2002 at 4:29 AM
There are bugs in Poser, one of which seems to cut out shadows. I have PZ3 file of a sunlight simulator. It works okay, but if I add the lights to another scene - no shadows. I just got some Pro pack Python scripts for light management which allow you to remove all lights from a scene before adding new ones and these have helped.
