cheers,
dr geep ... :o]
edited 10/5/2019
The "geep-sticks" come with the ambient color used so that they are highly visible in all modes. (except silhouette if there is something behind it)
Note: Turn the ambient color off if you want to use different colors because the ambient color will override or wash out the other colors.
All of the tick marks, and each group of 10 (or 12) are individual objects so you can "group 'em" and color 'em anyway you want.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
![file_266500.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_266500.jpg)
Now you can scale your props and people exactly! I did the metric versions for my friends "across the pond." ;=] ********************* IMPORTING PROPS ********************** If you have created a prop TO SCALE in RDS or Carrara ... When you "import" the prop into Poser ... ->"uncheck" the "Percent of standard figure size:" box ... ->Import the prop and change the prop's "Scale" to : ->4.2% (for RDS) ->1.05% (for Carrara) ->then (menu) "Figure" ----> "Drop to Floor" Your prop should be the correct size. (and on the Ground) ************************************************************ To change the prop's "Scale" (to 100%) without changing it's (apparent) physical size ... ->Export the prop - make sure the "As Morph Target" is NOT checked. ->Now "import" the prop again and it will load at the same size but it's "Scale" will be 100%. It's a good idea to do this BEFORE you save your prop to the library because very small Scale (%) values make it very difficult to adjust it's size later on. ************************************************************ If you would like to have a prop "resized" to scale, just let me know. Happy measuring! cheers, dr geep ;=]Remember ... "With Poser, all things are possible, and poseable!"
cheers,
dr geep ... :o]
edited 10/5/2019
