Mon, Feb 24, 6:17 AM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2025 Feb 23 2:34 pm)
Subject: Poser Files Corrupted?
dorothylee ( ) posted Sat, 02 February 2002 at 6:53 PM · edited Mon, 24 February 2025 at 3:32 AM
Is it possible that the computer corrupted a file when it was last saved? I did several test renders on 3 different images and they won't render. They rendered in the test stages and then the final test stage they wouldn't render and there was also no possibility of saving it full res either - I tried. I had another image that had about the same amount of props and texture maps sizes that rendered just fine earlier today. The problem with these 3 images started last night, so I don't believe there is a problem with Poser - just these 3 files. Is it possible that the files are corrupted or do I just need more RAM (only have 96 mb and use a lot of props now). Help!
ScottA ( ) posted Sat, 02 February 2002 at 6:58 PM
Although it's never happened to me personally. Poser corrupts files a lot for some people. ScottA
Ericroy ( ) posted Sun, 03 February 2002 at 11:54 AM
I've salvaged some corrupted poser files by starting a new file and then importing the corrupted one. It's not perfect, but sometimes it saves having to re-create the entire thing. The import file list doesn't display compressed files, but if you know the file name and enter it manually, it seems to work. Hope this helps, Ericroy
