Wed, Feb 19, 7:19 PM CST
Forum Moderators: RedPhantom
Subject: Min Threshold for delta values on Morph Targets.
Mason ( ) posted Mon, 04 February 2002 at 10:36 AM ยท edited Tue, 26 November 2024 at 9:07 PM
Does anyone know the minimum value threshold on morph targets wher ethe value is considered 0 and discarded? I have multiple morph target import working in Morph Manager 5 but want to make sure I don't discard too many vertices. I'm estimating around 0.001. The MTs I've tried work fine but I want to make sure I'm not culling out too many vertices or including too many making the MT bloated. BTW Morph Manager 5 will be coming out shortly and I will be needing Beta Testers. It will include: 1. Multiple Morph Target importing with drag and drop. 2. A channel organizer to arrange you MTs and channels any way you like including sorting them in alpha order. Also allows you to put in seperator MTs that do nothing except split your MTs into visual groups. 3. Display of the file in a hierarchy tree like in Poser. All channels can be viewed, copied, renamed etc. No more difference between CR2's and other files. 4. Copy and delete ability for full body MTs. 5. A material resource organizer that allows editing of material paths and obj file paths so you can have your cr2 references resources on other drives etc. 6. Bug fixes like making sure MTs or props don't get copied to the wrong figure in a multi figure cr2.
JeffH ( ) posted Mon, 04 February 2002 at 11:30 AM
I don't think I can help you with the delta values, but I might have a suggestion. Can you include an MT OBJ Stripper much like Morph Squeeze used to do?
Mason ( ) posted Mon, 04 February 2002 at 12:20 PM
What would this stripper do? Would it remove any 0 set MTs or something like that? That's real easy to stick in. The MTs are already optimal in the cr2. They don't contain any texture or normal info, just the vertices that have changed and those deltas.
JeffH ( ) posted Mon, 04 February 2002 at 1:18 PM
It would just remove all facet, normals and UV data from an OBJ file so it would be safe to distribute as an MT.
Vaio_Con_Dios ( ) posted Mon, 04 February 2002 at 2:22 PM
http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=556413, look at this message here you will find a link with many face morphs. VCD
Jaager ( ) posted Mon, 04 February 2002 at 3:01 PM
Does this help? V2 rForeArm elbowfix set dial, export, apply, save CR2 dial = 0.01 = 314 deltas dial = 0.001 = 244 deltas dial = 0.0001 = 8 deltas by the way MM4 crashed when exporting to geometries Vic's forearm - the buttock always crashes it. It may be better just to make a value judgement and say a dial setting below 0.01 is silly and drop everything below it.
Mason ( ) posted Mon, 04 February 2002 at 3:52 PM
well Jeff I think mm4 exports only vertices but if not I can easily arrange it so it only exports vertices. Though I would have to make sure my loader loads an MT with no faces. I can write a seperate app that does the morph squeeze. Jaager. I think I fixed this. MM4 couldn't handle obj with - values for vertex indices. I'll try the vicky buttock tonight (no jokes please).
Mason ( ) posted Mon, 04 February 2002 at 3:56 PM
You know, I could also make this a user option so you can enter your own threshold value. That way you can adjust an MTs resolution to trim it for redundant values. 0.001 seems to be fine. Does anyone have an email address for one of the tech heads at Curious Labs?
Jaager ( ) posted Mon, 04 February 2002 at 4:17 PM
Do you want me to send you the morph in the text so that you can see the cut value? It came to me that e = 10 and not "e" Or anyway, there is nothing smaller than -1.013279e-006 On the 0.001 setting Spawn saved no deltas Apply had 8 deltas with the above value.
dlfurman ( ) posted Mon, 04 February 2002 at 8:55 PM
Yes! For Option #2! Double yes for Option #5!
