Fri, Feb 7, 2:55 AM CST
Subject: I am in some need of advice from the learnerd artisans of Renderosity.
anthonyw ( ) posted Thu, 07 February 2002 at 7:45 PM · edited Fri, 07 February 2025 at 12:40 AM
I am in some need of advice from the learnerd artisans of Renderosity. I am stumped on something very stupid.... Let me just set the scene: I am trying to blend a Brass material with a Rust material. The Brass at the top will be blended into the Rust at the bottom. I have no problem setting up the blending but how do I apply the Rust Material onto Material section B?. I can not seem to get a material preset out of the Material Gallery and applied to Section B. Thanks Anthony
weirdass ( ) posted Thu, 07 February 2002 at 8:46 PM
Attached Link: http://www.weirdass.net
Try holding shift and clicking the diffusion/ambience mix to pull from column a AND b. Mess around a bit. You could also fake it by moving a duplicate version of the object clothed in material "a" closer to the camera and applying a semitransparent version of material b Or two renders and photoshop em together Mitch
anthonyw ( ) posted Fri, 08 February 2002 at 6:44 AM
Thanks very much for the info Mitch. Atleast now i will not spend anymore time on this now I know. Anyway I am giving the photoshop part a try now. Cheers, Anthony W
Tekchip ( ) posted Fri, 08 February 2002 at 11:13 AM
well short of two renders and probably saving a little time would be to blend the texture its self in photoshop and then load it via the texture editor. Same thing, less time.
