Mon, Dec 23, 11:08 PM CST
Subject: Flash Question
Kolschey ( ) posted Fri, 08 February 2002 at 12:38 PM ยท edited Mon, 23 December 2024 at 10:54 PM
As there is not a specific forum here dedicated exclusively to Flash, I thought I might ask here, as a number of Poser users like myself use the Pro Pack to export animation in flash format. The question is this: What do I need to do in order to give the property to a button on a flash site so that it will serve as a key for e-mail? Surprisingly enough for a web application, NONE of the three books that I have on Flash (and that includes the manual!) cover this issue. Any help you can give will be greatly appreciated!
Impudicus Rex ( ) posted Fri, 08 February 2002 at 12:53 PM
Try using the Flash "getURL" command appended with the "mailto:" HTML.
Impudicus Rex ( ) posted Fri, 08 February 2002 at 1:01 PM
more specicicly: on (release) { getURL ("mailto:sombodysEmail.com", "_blank", "POST"); }
Kolschey ( ) posted Fri, 08 February 2002 at 1:08 PM
Excellent! That worked perfectly. Many Thanks!
Impudicus Rex ( ) posted Fri, 08 February 2002 at 1:10 PM
The "POST" command may not be needed in your case, if you're not working with dynamics, that is (PHP, ASP, XML, et al ...)
saxon ( ) posted Fri, 08 February 2002 at 1:54 PM
I've a group over on Yahoo Groups for Poser, Flash and erotic stuff called Flash_erotica, you'll find it in computer animation.
