Vue F.A.Q (Last Updated: 2025 Feb 23 3:59 pm)
This is a first attempt at creating a semi-realistic representation of a black hole and companion star, still in progress, but gives you a general idea! The main star is a combination object, a quadratic point light set to volumetric and a sphere of mixed materials. The black hole was a 3D surface model I created with a material texture built to give the impression of matter being torn apart by the extreme gravitational forces close to the event horizon, with the accretion disk. As an additional effect I added a narrow beam volumetric spot to give the impression of a superluminal (ie faster than light) stream of photons as the last dying signature of matter at the event horizon!Anyway it looks quite good so far. Need to build the matter stream from the companion star to the accretion disk now.
Lester
