Sun, Jan 26, 12:31 AM CST
Subject: Need feedback on Morph manager 4.0
Mason ( ) posted Mon, 03 January 2000 at 6:27 PM · edited Sun, 26 January 2025 at 12:21 AM
I'm not trolling for any pats on the back but I need to know if this is working for people or whether I layed an egg. I'd hate to think 522 people downloaded a dud. Please send any major bugs to me at the attached mail address. Thanks
JeffH ( ) posted Mon, 03 January 2000 at 7:09 PM
Will do. -JH.
Cage ( ) posted Mon, 03 January 2000 at 10:34 PM
I haven't tried the new version yet, but the old one automatically opens to My Documents, where cr2's are obviously not kept. Is that just me and my system, or part of the program?
Sprout ( ) posted Mon, 03 January 2000 at 10:37 PM
Mason, i have used it to modify 2 characters already, so far i I am very pleased with it. Only one question, I still cannot export a single morph target into an object file? Is it just me or is that feature not applicable at the present time? Other than that I think it turned out AWESOME I like the new layout with more options and more colors :O) Thank you Very Much for the Great utility!
LoboUK ( ) posted Tue, 04 January 2000 at 4:20 AM
I've only had it a day and I already like it a lot. So far I've had absolutely no problem with it - works like a charm. If I spot anything, I'll let you know Paul
poser ( ) posted Tue, 04 January 2000 at 7:14 AM
Haven't tried the latest yet but all your earlier work was very welcome and useful. Please keep 'em coming. Alex
Ikyoto ( ) posted Tue, 04 January 2000 at 7:46 AM
To date it works great. It has ben tested on three machines: P-II 400 running Windows 98, Pentium 100 running Windows 95 and a Celeron 360 running Windows 2000. I don't have a use for all the new features, but I wil experiment with them untill I either get it to fail or find that you should be developing apps for what ever company is bright enough to buy Poser.
f91 ( ) posted Tue, 04 January 2000 at 4:06 PM
Hi Mason! This morning I finally have time to test your Morph Manager 4.0. I used your Wonder Girl to run this test. I have no problem to export any body morphs, but when I try to export suitchest morph as obj is said This program has performed an illegal operation and will be shuts down I also tried Wonder Woman, but the result was the same. Is this a bug?
Mason ( ) posted Wed, 05 January 2000 at 12:07 AM
Thanks f91. I'll try this myself udner the debugger. As for Sprout's question. You need to load the original obj file mesh to export a morph target. The cr2 only stores the offsets, not the original data. That has to be reconstructed by MM. Click on the Obj Fiel Button (Third above each window) or drag and drop the obj to the correct figure window. As for the open to desktop question. That's the standard dir all apps tend to open and save to. I have not yet found where Poser registers itself with a path. If I can find that then I'd use that directory as the default.
Mason ( ) posted Wed, 05 January 2000 at 12:40 AM
Ok, found the export problem with Wonder Girl suit chest and fixed it. A new Morhp Manager v 4.01 is now posted to the link. The problem was the file name was limited to 8 characters. If you rename the file to less than 8 then you'll be fine. The new version allows for 80 characters. A little typo on my part :)
f91 ( ) posted Wed, 05 January 2000 at 1:26 AM
Thank you for fixes this problem Mason! I will try the new version.
seang ( ) posted Wed, 03 January 2001 at 6:32 AM
Thanks for a great program. However is there a way to import obj (morph target) files to a loaded cr2 figure? I'm not sure if this feature is uncluded in morph manageer. I know this can be done in poser, but I have lots of morphs and would like a faster way to copy dozens of morphs to a figure. Thanx again :)
