Thanks geep, this will come in handy!
Poser 9 SR3 and 8 sr3
Processor Type: AMD Phenom II 830 Quad-Core
Hard Drive Size: 1TB
Processor - Clock Speed: 2.8 GHz
Operating System: Windows 7 Home Premium 64-bit
Graphics Type: ATI Radeon HD 4200
System Ram: 8GB
BTW - Re: copying the text. You can also "click" and "drag" to hilight the text you want to copy ...
then, right "click" and "copy" ... (see above)
Now, open your favorite word processor and "paste."
Voila! You've got text!
cheers,
dr geep <---------------------------------(feelin' kinda pastey)
cheers,
dr geep ... :o]
edited 10/5/2019
Hi geep, I got the cut/copy/paste thing down. I was just wondering if there was a way to paste it into a jpg or other graphics file in photoshop. Since the photoshop type tool is the only type related thing I doubt it's possible. Maybe the ol' "print screen" key is the only way. You know I must need glasses I looked for typo's and I still missed one, I didn't know texture had 2 u's! That must be the artsy fartsy pronunciation...
The test setup had a single cylinder with 5 horizontal "slices." Each slice had it's "Falloff" set to a different value from 0.00 to 10.0 as shown. The "falloff" values are constant for each of the 25 samples.
A cylinder was used because it has both a curved surface (x axis) and a flat surface (y axis) at a varying angle.
A single infinite white (100%) light
was located at x=0, y=0, z=0.
Shadows were turned OFF.
Anti-aliasing was not used.
This chart is intended to be a general reference guide only.
The transparency function can also be affected by object color, light(s) color and setting, texture color, bump maps, and reflection maps and settings.
This chart is not intended to be an absolute reference but a general guide depending on the effect that is trying to be produced.
The "Trans-Min" and "Trans-Max" values used are shown in chart#2 and were varied in 25% steps, e.g., 0%, 25%, 50%, 75%, 100%.
The "Trans-Min" is shown from 0% to 100%. (left to right)
The "Trans-Max" is shown from 0% to 100%. (bottom to top)
The 3rd picture shows the test setup.
cheers,
dr geep ... :o]
edited 10/5/2019
