Tue, Feb 18, 5:37 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
Subject: Creating Fairies
Kendra ( ) posted Fri, 15 February 2002 at 1:01 PM ยท edited Tue, 07 January 2025 at 6:36 AM
I've got the face and the ears the way I want them but is there a good tut out there for wings? Should they be modeled and attached to the figure? I have the free Amorpheum program and am trying to learn it, does anyone have a suggestion?
...... Kendra
zoozI2000 ( ) posted Fri, 15 February 2002 at 1:51 PM
Well, I created 10 wings props (Wings Lab) with Rhino. it's easy and takes few minutes. contact me, and I will explain it to you if you would like. zoozi@newmail.net
shadowcat ( ) posted Fri, 15 February 2002 at 2:43 PM
If you want to make your own, I would make them as smart props or conforming items. if you attach wings to the model you will have problems with repositioning them for different poses. Unless of course you want to make them jointed. hmmmm... that gives me and idea with the 6 armed characters...hmmmm... diving into poser & anim8tor.
bushi ( ) posted Fri, 15 February 2002 at 4:56 PM
Attached Link: http://home.velocitus.net/bushi/MakingFairyWings/
I'm just rebuilding my site on a new server. I loaded a tutorial on creating fairy wings using only a paint program. It should help get you started at least.
Kendra ( ) posted Fri, 15 February 2002 at 5:39 PM
Great suggestions. I wasn't thinking along the lines of a smart prop but that sounds better.
Zoozi, I don't have Rhino but I'll contact you.
Bushi, thanks for the tutorial. I searched for a while this morning and all I could find was the Bryce tut for bat and fairy wings. :-) That would work in some cases.
...... Kendra
3dfilmdag ( ) posted Fri, 15 February 2002 at 5:54 PM
Bushi I check out your tutorial on how to make fairy wings... Thanks... It is so simple to do. Thanks for you guidance. If only we had more tutorials of this caliber.
shadowcat ( ) posted Fri, 15 February 2002 at 6:10 PM
well I attached Thornes wings to P4 vicky having a problem with the joints (there aren't any at all) also don't know how I would be able to share this when I'm done because it uses the mesh of 2 different figures. (I could probably get permission from thorne and encode it to the vicky mesh) back to editting the .cr2
