Mon, Feb 10, 9:56 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 10 9:40 am)
Subject: Can I delete props from a fiugre by eidting the cr2 files
triceratops2001 ( ) posted Sat, 16 February 2002 at 2:45 AM ยท edited Sun, 09 February 2025 at 7:39 PM
I try by the morph manager, but it crash. And I don't know how to do that by using the Cr2 editor. Can any one teach me ? thx!
VirtualSite ( ) posted Sat, 16 February 2002 at 2:47 AM
Depending on what the prop is, you would just select it and hit "delete".
triceratops2001 ( ) posted Sat, 16 February 2002 at 3:23 AM
It is that easy by using Cr2 editor? I have try and the figure go into pieces, may be I did some other thing wrong?
Anthony Appleyard ( ) posted Sat, 16 February 2002 at 4:06 AM
Load the figure onto Poser's stage in the ordinary way.Usethe two little triablles below the screen to select the un wanted prop. Then press the delete kay. No need to mess about in the CR2 file with a text editor. Then save the figure back into your Poser's library under a new name.
triceratops2001 ( ) posted Sat, 16 February 2002 at 9:35 AM
anthony, I know that way. When I copying morph by morph manager last time, I find the figure had a porp that I don't want anymore, so delete it. But then morph manager crashed. So I try Cr2 editor, and the figure goes into pieces, I just want to know ' Can I delete props from a fiugre by eidting the cr2 files'
Anthony Appleyard ( ) posted Sat, 16 February 2002 at 11:12 AM
That is a ticklish business. You would have to identify the "paragraph" that decribes the prop - it will contain the channels (zTran etc etc), and textures etc, and usually the prop's .OBJ file embedded at great length. You will have to delete that paragraph WITHOUT removing or leaving in a curly bracket too many. And you will have to delete any introductory short paragraphs that declare that prop.
