Tue, Feb 11, 2:32 AM CST
Subject: Problem using Bryce 5
prontot ( ) posted Sun, 17 February 2002 at 10:28 PM · edited Mon, 10 February 2025 at 8:00 PM
Hi all I got a problem here. I'm using Bryce as the medium to create background for my project. This is a sample of my scenery of what I have done : http://www.renderosity.com/viewed.ez?galleryid=137300&Start=1&Sectionid=0&Form.Search=prontot Now, the problem arises when I wanted to animate the scenery like animating the camera angle. It seem that all the trees (coconut trees) and cubes (ponds) that I created will be relocated back to their original position when I click the button to the last keyframe or any keyframe just I want to animate it. Why is this happening? I went through all the help files but none can solve my problem. Can somebody help me? I'm using Bryce 5 and running under PIII 1.0Ghz with 261MB RAM.
Alleycat169 ( ) posted Sun, 17 February 2002 at 11:08 PM
You need to create key frames for each object before you move the timeline to the end. Any object that is not keyframed will revert to it's original position as soon as you move the slider. If you're not real experienced with key framing you might want to use the Auto Key option.
prontot ( ) posted Sun, 17 February 2002 at 11:11 PM
Hey... thanks Alleycat169. I just select all and create a keyframe and all the object didn't revert to it's original position. Thanks again. :-)
