Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 3:39 am)
Yep, it is possible, when you get everything to where you like it you can hit spawn morph target ... This will affect everything that you have set up. You can then unmorph the other dials and set the combo one to 1 and you will be all set .. you cna delete the other morph targets all together in the heirarchy window if you show all parameters or something like that ... Hope that helps
You can do it inside Poser. Set the dials of your face the way you want them. Go to Object/Spawn Morph Target. Name it what you want the dial to read. You'll find a new dial with your face morph. You'll have to set the dials you used to create it back to 0 (You can delete them if you don't need them) Set your newly created dial to 1 and voila! There's your combined morph!
Hi Team, does someone know if it is possible to combine Morph Targets? I have made a face with Travelers MTs and want to put them into one dial that makes all the settings I've made with 6 dials. Any Ideas? Thanks in advance Chris
"It Is Useless To Resist!" - Darth Vader
