Sun, Jan 26, 1:37 AM CST
Subject: obp to obj
matsmolund ( ) posted Wed, 20 February 2002 at 3:21 PM ยท edited Sun, 26 January 2025 at 1:35 AM
Im a newcomer. How do I improt bryce opb objects in to poser? Do I need a converter or is it easier than that? Please help, Mats
thgeisel ( ) posted Wed, 20 February 2002 at 3:24 PM
sorry to say, that doesnt work!! Most of the things made for bryce dont work in poser.
VirtualSite ( ) posted Wed, 20 February 2002 at 3:30 PM
All you can export from Bryce is anything made with fractals: terrains or rocks. Everything else is propietary.
Bubba ( ) posted Wed, 20 February 2002 at 3:56 PM
It's true that most of the presets that come with Bryce are not exportable into other applications and as mentioned the terrains and rocks can be exported. However most of the imported objects that are in your Bryce library which came from different sources can be exported into other formats by loading the object, clicking the 'E' (edit object) button and then pressing ctrl+D keys on your keyboard. This brings up a 'save as' window to which you can export the object in a variety of different formats. Usually if you have the edit object button available on your loaded object...it can be exported...USUALLY. Bryce can be contrary at times when performing this function, but most of the time it works just fine.
Hiram ( ) posted Wed, 20 February 2002 at 4:33 PM
Bubba, thanks for that tip!
judith ( ) posted Wed, 20 February 2002 at 6:32 PM
Keep in mind, you may have to remap it in UV Mapper though. Texture maps are generally only generated with objects created with the terrain editor.
What we do in life, echoes in eternity.
E-mail | Renderosity Homepage | Renderosity Store | RDNA Store
Poppi ( ) posted Wed, 20 February 2002 at 6:47 PM
Grrrr...I just ended up redoing a whole graphic because i wanted ot use one .obp file and could not export.
