Tue, Feb 11, 7:32 AM CST
Subject: Modify_Plants?
vibes30 ( ) posted Wed, 20 February 2002 at 6:00 PM ยท edited Mon, 03 February 2025 at 1:05 AM
Is there a simple way to adjust the texture maps on the plants, trees, ect..? I am thinking along the lines of changing tree, plant leaves to more of a fall look or if it is possible to assign the leaves a transparency so they look leafless :) Winter style? Any comments or suggestions welcome. Thanks
Axe555 ( ) posted Wed, 20 February 2002 at 6:51 PM
If you go to the Vue tutorials section there are some tuts on this by Guitta. Varian and Guitta both have alternate plant mats at their websites as well. Making the leaves invisible is an easy one. Open your material browser (button on the toolbar that looks like three spheres), edit the leaf mat you want to change, and set the transparency to 100%. Varian also has some excellent tuts on ways to use multiple trees together as one tree (you'll find his site through the Vue tutorial links as well). Rich
kruzr ( ) posted Wed, 20 February 2002 at 6:55 PM
Attached Link: http://www.multimania.com/arte/index.html
'Afternoon vibes30 . . . . . 8^) Here's a great place to start, there's more than enough to get you going, and Guitta has a vast knowledge of all versions of Vue. Good luck & have a good one . . . Mark. . . ;^)
vibes30 ( ) posted Wed, 20 February 2002 at 11:35 PM
Much thanks to both of you! I knew it was probably possible but it is even more than I expected - Thanks
