Mon, Dec 2, 3:03 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 02 2:40 am)
Subject: I have a question about Poser setup?
webraiders ( ) posted Thu, 21 February 2002 at 9:35 AM ยท edited Fri, 09 August 2024 at 1:37 AM
I maybe missing something? I don't use Poser in full window mode, I like to have it setup as a smaller window so I can see other thing that I am working on. Here's my question, how do you get Poser to stop openning up in a full window and keep it the was I have it setup. I have tried to use the "Interface Preference" and "Document Preference", they work fine for my work area in Poser but do not change the window mode at startup. Thanks!
argus1971 ( ) posted Thu, 21 February 2002 at 10:51 AM
Try editing the icon you use to start Poser. Right click on it and go to properties. A new dialog box will appear with some tabs at the top. Click on the shortcut tab and you will have some text boxes below. Look for the run section. See if "normal window" appears or not. If not, selct it by clicking on the down arrow. If it is there, you may have to resort to manually changing it from maximized to windowed.
