Attached Link: http://www.derby-vi-service.demon.co.uk/pictures.htm
Attached Link: http://www.mmedia.is/~bjj/data/saturn/rings.html
Zoon, The first image is exactly what I'm looking for! Now, I understand using the numbers to form a greyscale strip (I am assuming it is like the one on the link containing transparency data). I guess my real question is how to get that data from the strip into a concentric ring texture that is capable of being mapped on an alpha plane? I use Paint shop Pro (Mainly cause it was cheap and pretty functional). Do you make an image with concentric circles and use it in greyscale as your alpha map? Sorry if I appear a bit pedantic. You have some wonderful images on your site, I appreciate the replies. Dr. Nash
I did it in Corel Draw, and then converted to a bitmap. I've just shifted 30 3 foot by 2 foot concrete slabs, so I'm going for a long bath. IF I get out of the bath this evening, I'll post some details of how to do it. The final bitmap is 20mb, and even zipped its 6 mb, so showing you is going to be easier than sending the image!
Ok, I'm flummoxed. I have tried to use a torus with the actual "Map" (Obtained from a NASA website. Won't map at all correctly. I've tried an alpha plane with variable levels of transparency. Nothing that I've tried will work to any satisfaction. The closest I've come is to use a series of nested torii, but it's still not good enough. There is no way to isolate the "Saturn ring" from the planet would there be? (BTW, is there any way of using the "Planet" object and having it accept other maps? Of course a map can be applied to a sphere, but the result is less than stellar. No pun intended... yeah right.) Does anyone have any suggestions? I've only been using Vue for about three months or a little more so I'm not a Grandmaster, but not COMPLETELY hopeless. Thanks Dr. Nash
