Okay....THe pony is one of the "must haves" in my opinion. Here is how to make it work every time. When you first setup your poser figure....go to figure...and click on inverse kinetics on both the right and left leg. Then, click on any body part on the figure...go to window...joint editor....and hit align...this will position your figure perfectly to take anton's hair. Select the hair out of the figures menu, and, click on the double check mark at the bottom...this will stop your vicki from disappearing when the hair comes in. If you have the expansion pack....now is the time to play and get the "style" that you want. Now, click on figure vcpc, under your poser window....hit body parts...select base....go to figure, change parent...and parent it to the head of figure 1(vicki). now, go to object...lock...and you are set...the hair will pose perfectly with your vicki. Hope this made some sense. i do love my expanding pony...it is so very useful.
HI I recently purchased the Ponytail Collection From DAZ. But I do not have the skills to make it work for me. I do not know how to make the hair stay on the head through-out the posing process. The Hair comes in as a Figure. not an Object. Is this a difficult process on learning how to make hair that is a figure work like an object that you can lock? Thanks for any answers to this question Prema
