Tue, Feb 11, 12:08 PM CST
Subject: Need Help
JHILL ( ) posted Mon, 25 February 2002 at 10:34 PM · edited Tue, 11 February 2025 at 12:05 PM
Ive downloaded some objects off the web to use in Bryce. All of the ones I downloades are in 3ds format. Is there anyway I can change the format so that It is in a Bryce format. I would like to add the objects into my user folder. Thanks in advance.
Kate ( ) posted Mon, 25 February 2002 at 11:08 PM
File => Import => Once in the object is included in the scen select it and go to objects => add Hope that makes sense ;)
Vile ( ) posted Mon, 25 February 2002 at 11:08 PM
Go to file and import object and import the 3ds model. Then choose the model and open the create dialog box (where your objects are) and click add. No need to change the format. Good Rendering
Alleycat169 ( ) posted Tue, 26 February 2002 at 8:43 AM
Before I import a 3ds model I run it through Maconverter, this usually makes the textures import cleaner. You can import them without converting too. Bryce has a pretty wide range of files that it can import and export.
JHILL ( ) posted Tue, 26 February 2002 at 9:18 AM
WHERE CAN I GET MY HANDS ON MACONVERTER? I WOULD APPRECIATE IT. THANKS AGAIN EVERYONE
inyerface ( ) posted Tue, 26 February 2002 at 11:20 AM
http://www.soft-rabbit.com/
