Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 7:25 pm)
Are You using the same skin texture for all of her body? i am sorry that i am not sure what to do to help you. i have Eve but the texture with her aligns fine. If you are using just the one texture map, pull it into your paint program and make certain it is aligned correctly on the jpg itself. Beyond that and checking your render options to be certain you are using the same eve skin texture on all parts of her body, i am uncertain what else to tell you. Good luck. odyssey
I tried it this morning, and inadvertently got the same results...until I found out that Poser loads the default P4fem or woman texture for Eve...check in your "textures for Eve" (or whatever name it's got) folder for the "NEW P4 nude woman" texture, and load it in the materials dialog in the textures setting for the skin. The genitals have been removed from this body texture because you have to apply a special map (genmap) for the labia and vagina on Eve, so if you forgot to load the special body and geniatls map, the painted genitals show. I just hope it helps. You have got to be patient, attentive and frustration-proof. Most of the time the problem is sitting in the front of the 'puter. :-)) purplehayes
