Also you may need to turn the ground plane on in the Hierachy. I always use a one sided square from the props, and put a texture on that. You can make it whatever size you want.
The greatest part of wisdom is learning to develop the ineffable genius of extracting the "neither here nor there" out of any situation...."
I was wondering if there is anyway to make a floor in poser...as in adding a texture? I tried to follow some directions I read somewhere but that just didnt work. Here are the directions...1. Open Material Menu or (PRESS CRTL U) 2. Select Ground on the object panel. Select "Preview" on the Material Panel. 3. Press the load button at the Texture Map box. 4. Load the selected Poser Floor from the installition location on your Hard drive. 5. Keep the Texture strength at 100%. 6. Press the OK button at the bottom right hand side of the Surface Material panel. Any help is so appreciated! Thanks.
