Win 98, unfortunately, so most of the neat tricks to change my allocation won't help. Yes, I know, I need to upgrade to XP. 125 MB RAM. Usually it's not this bad. I've got FreeMem that usually seems to do the job for allocation, but even IT is choking on this one scene. I just can't figure out what part of it is so amazingly too much. Gaaaah.
Might not be a memory problem. Sometimes Poser gets confused and the scene becomes unstable (this might have happened in any saved version). My advise would be to reboot, construct a simple scene first, render it, save it, load it and render it again. Then start building from scratch. This worked for me several times. I never had a persistant problem with any scene in Poser. Complex scenes just become terribly slow. Pose each figure separately, save as a character, reboot, start Poser and move each figure in, then render and wait and wait, finally something happens and the screen starts building up.
Another thing you can try is to deal with Michael and Victoria. With all of those morphs, they're real resource hogs. If you're rendering a still-frame image, you can export Mike and Vicky, fully-clothed and posed, as .obj files, and then load those into the scene instead of the CR2's. You'll have to reapply the bump maps and transparencies, but the meshes alone will only consume a few megabytes each, and you won't have the overhead of all those morphs clogging up memory. If it's an animation, you can still do some trimming on both characters with Morph Manager, removing unused morphs.
I thought I was the only one this happened too. Traveler, question, when you remove a texture in the materials doesn't it still stay in the memory. Example, you are fiddling with a scene and change a lot of things with textures but you don;t like it so you delete it. I have noticed the textures still stay. Any way to get rid of these. If you save the pic it saves the textures not being used also.
In a world filled with causes for worry and
anxiety...
we need the peace of God standing guard over our hearts and
minds.
Jerry McCant
I don't think that Poser stores the images in memory, because if you render, then alter the map, save it, and re-render poser updates it. So it must draw the file in when rendering. What may be stored in memory is the location and maybe the low-rez version you see in the texture display mode. When rendering poser will draw in the bump map, trans map, textures, generate the shadow maps, etc. That is where your memory is being chewed up.
Thank you so much Traveler. I was wondering if the lights had anything to do with it. I am soooo lousy at lighting that sometimes I have a lot of lights, many blacked out. I need to try that.
anxiety...
minds.
Jerry McCant
I've found the limit as to what my laptop will render. I've got a Vicky and Michael in the scene, both closed, a PWFW set, one of REMC's undead, and a few other props. And my laptop chokes every time, even after a fresh reboot with everything but Poser shut down. Her hair isn't too complex (Koz's wave), his is the Daz Wedge. None of their head/body textures are over 2000x, most are closer to 1400. Lighting is minimal, one of the "Illustrender" sets. The way the scene is set up, compositing would be a serious pain in the ass. I'm not even sure exactly where it reached the "too much" point, either. I know that it would render last night before I added the zombie corpse, but I don't remember if I changed anything else between then and now. Anyone have any ideas as to how I could enable the render without sacrificing elements or quality
