Thu, Nov 14, 6:24 PM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: Help needed..I'm new and slightly retarded..haha
rustofumes ( ) posted Thu, 14 March 2002 at 6:06 AM · edited Fri, 09 August 2024 at 4:58 PM
I'm new at this so bear with me... =)
I'm having problems with some of Royloo's conforming figures.
For instance I can't get the "bulletvest" to load in my Poser4 or the "one-piece suit".
Unfortunately his stuff doesn't come with any detailed instructions or the usual files that are already pre-stuffed in folders, which leaves me to manually catergorize the seperate files myself.(YIKES!)
I put the .cr2 and the .rsr files in it's own folder labeled "Royloo" in the libraries/character folder.
I put the .obj file in its own folder in the geometries folder.
Last but not least I put the .jpg files in it's own folder in the textures category.
Still nothing...Arghhhhhhhhhh!!!
Need help....please...must..get...help...
leather-guy ( ) posted Thu, 14 March 2002 at 6:55 AM
I don't know what error message (if any) you may be getting, but I'd first check to make certain the OBJ file is properly placed. Open the CR2 in a text-editor (Wordpad will do). Near the top will be a line like the following: figureResFile :Runtime:Geometries:Foldername:objfilename.obj Make sure the OBJ is in a folder exactly where described. Including capitalizations - it's extremely case-sensitive! Good luck:-)
rustofumes ( ) posted Thu, 14 March 2002 at 7:54 AM
Thanks!! I'll try it..
