Mon, Jan 20, 11:53 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
Subject: how do I get rid of this?
juju-b ( ) posted Fri, 15 March 2002 at 2:32 PM ยท edited Fri, 02 August 2024 at 8:00 AM
I know.... another eyebrow question, but I just can't seem to get it right. I finally got the hair to show up, but how do I get rid of this?
thanks
juju-b
lhiannan ( ) posted Fri, 15 March 2002 at 4:01 PM
is that the upper or lower eyebrow? if it is lower, make sure the texture is applied to it. If it is the upper, you will need to either turn it completely transparent or sink it into the head.
juju-b ( ) posted Fri, 15 March 2002 at 4:22 PM
It is the upper brow. I just applied a trans brow. I kept the trans min to 100% and trans max to 100%. Texture (?) juju-b
Nance ( ) posted Fri, 15 March 2002 at 5:11 PM
Then are you sure that you are not still looking at the (unmapped?, untinted?) lower brow behind the transparent parts of the upper brow? ...Or that the black parts of the transmap are not 0.0% luminance.
lhiannan ( ) posted Fri, 15 March 2002 at 6:22 PM
Ok, like Nance said, make sure the lower brow is textured. In the pic above, the Right side is with the face tex applied to the entire head, with a brow trans on the Upper brow (trans min set to 0, trans max set to 100). The Left side, everything is the same, but I removed the texture for the Eyebrow (Upper is still textured).
juju-b ( ) posted Fri, 15 March 2002 at 7:22 PM
Great, thanks for the help. Which one is the lower brow....Eyebrow or EyeBrow? J
lhiannan ( ) posted Fri, 15 March 2002 at 8:43 PM
I don't remember the exact casing, but it NOT the one on the bottom of the list (after Fingernails, ect.)
FishNose ( ) posted Sat, 16 March 2002 at 2:13 PM
Best solution - switch off your computer, go take a beer with some friends. Then those eyebrows won't bother you any more :] Helpful, huh? :] FishNose
juju-b ( ) posted Sat, 16 March 2002 at 8:56 PM
yea, but the eyelashes will!!!!!!!! :)
