Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
O.K. UnZip files, place were they belong. You can place them with Winzip the way you normally do or manualy. Open mover and click decode and put seed file in, that would be P4nude woman obj. file in geometres, put the PCF, in the differece file, click convert, now you have a new obj. file. thats all there is to it. Tashar 59
Stuff from MorphWorld I have found always do just what they should but I have gotten into the practice (based on other stuff elsewere) to simply unzip all ZIP files into a special Empty on my root C: and then manually 'put them away'. I started doing this for many reasons especially as it allows me to keep things 'tidy' on my HD and....because some files don't do what they say AND because some makers have slightly different folder structures than my Poser set up. Just be very attenative (i thinks that's a word?) to the Geometries folders and remember they ARE CaSE SeNsItIvE!!
Attached Link: http://www.hiab-x.com
Hi there , here is a transcript of an e-mail I sent to the creator of Eve and Azura. Appreciating he's got better things to do than answer every query , um, and given that Iv'e not yet had a reply , I'm hoping someone here will patiently set the following straight for me please.... "Could you please clarify a couple of points in my mind regarding the unpacking and installing of the Eve and Azura files please ? 2.) Unzip them to your Poser directory, and in the unzipping program, make sure that you use the folder names option, so that all of the files are put in their proper places. OK, I read this as extract all respective zip files over to the main Poser 4 directory in my C drive programs folder. The bit I feel uncertain about was making sure I use the folder names option. Normally when I use winzip I just hit 'extract ' to the directory I want to install to . Is this not the case in this instance ? Iv'e never used mover before , but I'm assuming that even with all the Eve and azura files unzipped into poser, the proggie just does all the correct transfer and placements of all files. " I'd hate to make a complete mess up of the job so If you'd kindly advise I'll be grateful . Thanks HIAB-X
