Forum Moderators: Staff
If you set Poser's background color to WHITE ... - and - You can do a "Copy Picture" from Poser and then "Paste as transparent image." into PSP (with white BG set) Don't know about Adobe ... I'll try and find out. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
If your using Poser 4.03 saving or exporting images as a PCT, PSD, or TIF (no option for PNG) will give you a picture that will include an alpha channel. The alpha channel can then be used to make the background areas of a picture transparent Chris Cox
ok guys, this is my problem.. I want to export a poser figure to, for example, Adobe. Is there a way to leave the background color for what it is and ONLY save and export my poser figure?? I know..I know....I can erase the background in Adobe, but this is not always as easy, so I was wondering if there is a way to get my poser figure straight from poser to Adobe, without any background colors?? Thank you all for your response...
