I always try to save a completely zero version(pose & morph) into the library. :)
-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
Hi all, When Stephanie comes out of the library her "Stephanie" full body morph is set to "1". Before you spawn morphs you have to set it to "0". Otherwise the fullbody morph will continue to deform the mesh with each morph you spawn. The dials on each bodypart read zero but they are not at zero. Just go to the "body" and check before spawning morphs. If it is too late. How to fix: If, for example, your facemorphs have cinched her neck. 1)Zero her head and morph but leave the full body morph on. 2)Go to her head and spawn a morph target. This morph is the deformer poluting your morphs. 3)Turn that dial backwards until the deformation is gone. 4)Then spawn and export a fresh morph and reapply to a clean Stephanie. Anton
-Anton, creator of ApolloMaximus: 32,000+ downloads since 3-13-07
"Conviction without truth is denial; Denial in the face of truth is concealment."
NEW The Poser FaceInterMixer
