Sat, Jan 25, 8:24 PM CST
Forum Moderators: Staff
Subject: deleting morph dials
Curio ( ) posted Wed, 20 March 2002 at 2:59 PM · edited Sat, 11 January 2025 at 3:14 PM
Is it possible to remove a morph dial from within poser? and if so, how? Cheers, Pete
SAMS3D ( ) posted Wed, 20 March 2002 at 4:12 PM
Attached Link: http://www.sams3d.com/Tutorial.htm
if you know anything about cr2, just do it there in the cr2 file. You can download my tutorial, and get to the cr2 section and you will see what I mean. Sharen It is easy
Curio ( ) posted Wed, 20 March 2002 at 6:19 PM
Thanks! - but that mean it can't be done within poser?
ScottA ( ) posted Wed, 20 March 2002 at 6:42 PM
You can remove them using the hierachy window. Just X the show all option in that window. And you'll see them. Then you can select them with your mouse. And delete them with your Delete key on your keyboard. ScottA
Curio ( ) posted Wed, 20 March 2002 at 6:45 PM
thanks very much scott! I'm not too keen on text editing files!
cyber-organic ( ) posted Tue, 02 April 2002 at 1:29 PM
ScottA, does that just remove them from view or does it actually delete them the same way as if you edited the text file?
