Fri, Jan 24, 7:54 PM CST
Subject: The holes of Tessa
Estruch ( ) posted Sat, 23 March 2002 at 7:06 PM ยท edited Fri, 24 January 2025 at 2:44 AM
I dowload Tessa and she have many holes... Is possible evited this?
johnnydnh ( ) posted Sat, 23 March 2002 at 7:14 PM
It looks like someone took a shotgun to the texture. Open up the texture in any picture viewer and see if there are holes in the texture. If so, you will have to repair them using Photoshop or something like it.
wyrwulf ( ) posted Sat, 23 March 2002 at 7:16 PM
Estruch, what version of Poser are you using? It looks like a problem with the Pro Pack and characters with embeded geometry from using the grouping tool.
ElectricAardvark ( ) posted Sat, 23 March 2002 at 7:22 PM
That's not the texture, your normals are all goofed up.
sturkwurk ( ) posted Sat, 23 March 2002 at 7:34 PM
Update your Poser Pro to the curent version.
I came, I rendered, I'm still broke.
Estruch ( ) posted Sat, 23 March 2002 at 8:59 PM
I use Pro Pack
geralday ( ) posted Sun, 24 March 2002 at 12:30 AM
Can't get the problem to show on my system.. I'm not using Pro Pack. Tessa was created using Poser and Anim8or and features no textures.
Suggest you try loading Posette, remove the textures, and see if the problems in your software.
If the problem is widespread to other folks I'll do what I can to fix it.. but I've never seen anything quite as strange as this before!
Gerald
wyrwulf ( ) posted Sun, 24 March 2002 at 1:00 AM
The problem is as I stated above, and the fix is as sturkwurk has stated. Tessa is a great idea, but using the grouping tool and saving embeds the geometry in the Pz3/Cr2.
Estruch ( ) posted Sun, 24 March 2002 at 4:45 AM
I fix the problem with one Text Editor. change only two lines.... The cr2 wanted ony new obj file, after the cangue wanted the P4nuewoman.obj.... and fix the problem
