Wed, Nov 13, 10:51 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
Subject: This drives me crazy (morph import)
Seravajan ( ) posted Sun, 24 March 2002 at 4:11 PM ยท edited Tue, 12 November 2024 at 7:48 PM
Now have I finally finished a morph. I imported it into Poser. There a 2 dials for the morph. I pull on them and - NOTHING happens! :( What is wrong? Have I to edit a specific file after finishing the morph? Seravajan
elsja ( ) posted Sun, 24 March 2002 at 4:52 PM
Explain with more detail what you do. There is no reason to import a morph. For add a morph, select the body where you want add it. by ctrl-i go to the winbdows and click on the add morph button. In the new windows select the morph geometry and named. after push ok do the same operation for all the morphs you want in that body part. Once finisehd select another body part and so on for all morph of all body part you need. Remark : do not label two morphs with the same name. Next time you will use the figure you will keep only one. Hope that help. Guy
Seravajan ( ) posted Mon, 25 March 2002 at 2:37 AM
Yes. I know that but the program I used for making the morph layed me an egg. I had to export it first before I can apply it in Poser 4. It worked as intended after that. Seravajan
