Mon, Feb 17, 6:49 PM CST
Subject: Exporting Object from Bryce
smuey ( ) posted Mon, 25 March 2002 at 8:33 AM · edited Mon, 17 February 2025 at 6:31 PM
Could anyone please tell me how I can export an object I created in Bryce? I can't seem to get it right... Thanx!
airflamesred ( ) posted Mon, 25 March 2002 at 9:23 AM
terrains ,latice and stones only i'm afraid
Sipapu ( ) posted Mon, 25 March 2002 at 9:28 AM
Am I right in thinking that if you want to share a boolean object you've made with another Bryce user you can give them a copy of the .brx file that contains the object?
airflamesred ( ) posted Mon, 25 March 2002 at 9:59 AM
yes i think you would have to save the object in the objects pallete and export from there
Aldaron ( ) posted Mon, 25 March 2002 at 12:22 PM
well the .brx is the whole scene so that could work but if you'd like to send just the object you created to another Bryce user then you can save it in presets, export it and send the .obp file to them instead.
smuey ( ) posted Mon, 25 March 2002 at 12:32 PM
So if i get it right, there is no way I can, for example save it to a .OBJ file, for use with UVmapper? 'Cuz i'm not really happy with Bryce's way of handling textures on custom models...
Aldaron ( ) posted Mon, 25 March 2002 at 8:47 PM
Not if it contains Bryce primitives, booleans, etc. It can import other formats then export them in a different format if none of the none exportable objects from Bryce are added to it. If it contains only meshes and lattices (ie terrain, stones, symetrical lattice) then it can be exported.
bikermouse ( ) posted Tue, 26 March 2002 at 5:29 AM
has anyone here used world builder? are these just byrce problems? bryce takes this proprietary format thing too far you can't even model 3d environments for use outside the product. all but useless for 3d! - sorry it's just so frustrating so much potential locked up in those .brX files. I think that you would need to export the .obp file.
Rochr ( ) posted Thu, 28 March 2002 at 4:09 PM
Make sure that every part of the object is grouped together. While having the object selected, open up the objects palette, select a category and press "Add". Select the added object and press "Export". It will be exported as an .OBJ Done.
Rudolf Herczog
Digital Artist
www.rochr.com
Rochr ( ) posted Thu, 28 March 2002 at 4:11 PM
Sorry! As an .OBP...:(
Rudolf Herczog
Digital Artist
www.rochr.com
smuey ( ) posted Sat, 30 March 2002 at 2:54 AM
Allright! Thanx!
WadeTripp ( ) posted Sat, 30 March 2002 at 9:00 AM
Is there anyway to take items built from primatives to Poser? Wade
reddog ( ) posted Sun, 31 March 2002 at 1:56 AM
these problems are why i left bryce mostly not used for over 2 years. every time i needed a .obj file to make a texture it was blocked by no .obj export. would go to user book not there. i knew that i had done it before. then was guided to the FAQ page at the front of this forum and they had a way not eazy but but you can get the .obj file
