Forum Moderators: RedPhantom
I have Vickys Changing Ponytail too, have XP and the ProPack and it works fine. What exactly is your problem? With the expansion pack you got Posefiles - aren't they working? Try to select the base or the body of the hair first and then apply the poses - this should work. If you like to change the hair manually you have to select a bodypart: bangs, base or ponytail and you will see different dials. On the bangs and ponytail you find the dials Change bangs / Change Ponytail - when you set the dials to 1, 2 etc. you will see that the parts are changing. Now you can try the other dials that belong to this parts too. Hope that helps :-) Friederike
Every
organisation rests upon a mountain of secrets ~ Julian
Assange
First, are you sure it is my product. There are no "stringy" styles or elements in the Ponytail Collection. It is all thick, dense hair. Your discription is odd for sure. Post a pic. Most likely it is a very simple problem, since nnone else has had any problem with the poses. You can post the troubled render here or email me and we will figure out what you might be doing wrong. Even if it isn't my hair, I wouldn't worry. These things are always something simple but overlooked. Anton Kisiel antonk68@aol.com
-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
Is it possible that you are using the expansion pack poses on the base hair and not the expansion pack? you get a few odd styles when that happens, I know I kept doing that at first blush Do post a pc of it - because there really isn't any stringy hair - unless you mean the strands around the bangs...
3-D Arena | Instagram | Facebook
I do not feel obliged to believe that the same
God who has endowed us with sense, reason, and intellect has
intended us to forgo their use.
-Galileo
-Galileo
this is the action blow bob R with the correct hair applied Note: trying changing your camera focal as well tog et a better image - mine is set at 250mm, but many set it between 150- 200
-Galileo
The figtoria and Stephanie figures also do not load in at zero. -Turn off herIK chains for the legs. -Open "Joint Editor" and click 'zero" -Select Vicki's hip and body and zero the tran dials manually. -Now Victoria is at zero. Yo9u might want to save her this way or save her with the hair attached.
-Anton, creator of
since 3-13-07
Your Vicki is not at zero as I mentioned above. Select her body and hip and turn the tran dials to zero.
-Anton, creator of
since 3-13-07
also after you get the hair where you want it, check on the body of the hair and change the parent to vicky (or stephanie or even michael's) head. Then lock the body. The poses will still apply and you will still be able to adjust the rest of the hair, but it won't move on you.
-Galileo
I have the Anton Daz3d package when I try to use the poses that are preset it the hair looks like it went through a blow dryer from hell...I have been trying to get the bob cuts to work...but all I get is stringy long hair. Is there a problem with this package under Poser Pro or is it me not knowing how to run the program? The poses mat on other hair products I have bought are easy to use. I have all 3 products on this hair product.
