ok thanks i never even thought of changing the x y z dials on their own like that.. exporting it is a good idea...when you alter the cr2 will it resize itself to the new obj size or would i have to do that manually?? the way i figured it out, is i went into the propack setup room sized the figure in there to 132% and sized the cr2 to 132% to fit the new size. then back in the pose room all the dials are set to 100%
Ideally the new CR2 would be at baseline (100%) as far as scaling and morph settings are concerned. You would be generating a new version of the geometry and it would just be 132% larger than the original. You would then edit the two geometry calls in a CR2 file to use the new version. Its 100% would be 132% of the old one. If you edited the CR2 that it came from, and left the Body scaling at 132% - the model would be 1.32 x 1.32 larger than the original. (If you leave morph dials set when you export, this will also be a part of the new geometry- so any dials left on in the CR2 that you edit would be compounding their effect.) If this is just for you, you have many options, if it is for sharing, you would have to provide the new geometry - encoded.
is there a way to'reset' the dial that is 132% now, to 100% but keep the character 132% bigger... so like the starting point is at 100% again.
thanks for any help!
