Photography F.A.Q (Last Updated: 2025 Jan 22 8:17 pm)
What's LAB and which do you think is the best of your pictures. Aditionally you may want to resize this picture. I took about three minutes to load on my machine. I realize I'm using a dial up connection and my modem is a 33.6 BUT 3 min! I think things would be better if the picture was say 1/3 as large. Bsteph
I'd be interested in a tutorial about using LAB space in PhotoShop. Or even CYMK. Usually stay in RGB, but know some pretty neat things are possible. [I am a bit confused about your examples though. The one labled "original" looks the best on my monitor. But we've talked about my monitor deficiencies many times here before... ;-) ] Welcome to the Forum BTW.
Maybe I'm missing the point here, but why would you want to use those two curves ? Photoshop's standard stuff is (for me) more than sufficient to correct specific areas or specific colors or color ranges. Especially when using and storing (quick) masks, the options are endless. So, if it was meant to make the colors above more real, I don't think it's looks very good at all. Both the blue and red colors are too far off, as far as I can see :)
Same here Original image looks just fine to my eyes, but I'm no expert. The Curve One image looks too red and the Curve Two image looks too yellow (the womans skin has taken on a sickly yellow tone) and the highlights seem to bright to me in the last image. I've heard about lab space and have never worked in it, but if I did I would have to convert back to RGB in order to print my images from my Epson, no?
I am, therefore I create.......
--- michelleamarante.com
And thanks so much Alpha for defining lab in a way that i have to remember the next time i try and explain it. Please tell me that wasnt just 'off the top of your head!'
btw, image was scanned on a nikon 4000 with some incorrect colorsync settings. It blasted out my highlights and gave me some weird saturation issues.
This is a very good result...much better than the other.
Ahhhhh I get it. I always wondered why RGB was such a horrible system. It did not completely seem to work. I suppose cymk is better though. BUT what posessed people to think of that model! Wait a sec. So if I had a pic. with a said RGB value 12,13,14 and a darkness of say 15 then according to the model I can fkeep the RGB values tha same and just change the darkness. Fine but can't I do that in any other photo program just by adjusting the darkness. I'm not trying to poke holes I'm just trying to clarify. Seriously I would love to hear about that lab. Sounds like we will need new softwere(sp) though. Can this be applied to say psp? Oh and welcome to the forum. Bsteph
Rork1973: LAB can give you a real boost if you are trying to correct a really poor color image. it is not fit to process the image from beginning to the end, tho. It's the same with RGB. There are operations that are not possible with RGB or lead to poor results. An example of this is removing JPEG corruptions and/or cromatic aberrations on poor-scanned images. LAB leads to perfect results. Different ways to process colors. IMHO eartho give us a wrong example of what LAB can do; to me seems he has exaggerate colors in the worked pictures... The colors in LAB profile are not ordered in a logical way, but in a mathematical one. If I need to rework the colors of a pic (which i do the 99% of the times i shot a photo with my D1x) i prefer to do such work in a scale I can comprehend immediately. This doesn't mean that LAB can't do such task... sometimes comes in handy if you need some particular correction, but simply it's too complicated for a plain color correction.
