Wed, Dec 4, 8:13 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 04 3:06 am)
Subject: Need help with splines in cinema 4d
cmjackson ( ) posted Fri, 12 April 2002 at 2:40 PM ยท edited Tue, 03 December 2024 at 7:10 PM
Attached Link: http://the-internet-eye.com/HOWTO/1999a/poser_clothesa/dressing_your_poser_figures.htm
I know this is the poser forum, but i thought prehaps you guys who use poser might use this program as well. (I've also posted this in the cinema 4d forum as well) I'm following this tutorial how to dress your poser figures. But i'm stuck on the bit where it says about drawing a spline. I've found the spline controls but i can't draw a spline around the figure like it says on the tutorial. It would be most appreciated if someone could take a look at this tutorial and explain to me what to do. I'm obviously doing something wrong and it's doing my head in.
Could someone also explain to me what a spline is cos the manual makes no sense.
steveshanks ( ) posted Fri, 12 April 2002 at 3:09 PM
i wrote that, so first what version of cinema are you using ;o)......Steve
cmjackson ( ) posted Fri, 12 April 2002 at 3:28 PM
It's version 5.20 SE. Thankyou lovely man xxx
steveshanks ( ) posted Fri, 12 April 2002 at 3:42 PM
create an empty spline....objects/empty spline...leave it at default and click ok...then select points tool and Ctrl left click till you have created your spline BUT every time you click, drag the mouse a little to create handles and make the spline soft....once your nearly at the end stop and double click the icon in the object manager and check "close spline"...now adjust a bit and onto the next one ;o)........Steve
