Tue, Feb 4, 9:04 PM CST
Subject: help! a silly silly question
raz ( ) posted Fri, 12 April 2002 at 9:39 PM ยท edited Mon, 27 January 2025 at 6:41 AM
how do I erase or delete animatin frames BEFORE the frame I want to keep? I read somewhere its better to make several smaller animaitons then conbine them in a movie joiner. I want specifically to keep the last frame of the sequece, (frame 44), and delete 1-43 and start over with the second part (beginning with frame 44 as the "new" frame 1).
Little_Dragon ( ) posted Fri, 12 April 2002 at 10:03 PM
Use the animation palette. Select Animation Palette from the Window menu, or click the Edit Keyframes button on the Animation Controls (it's the one that looks like a key). Left-click-and-drag a selection box around the keyframes you want to keep, then drag your selection to the beginning of the timeline.
raz ( ) posted Fri, 12 April 2002 at 10:27 PM
ohhh.. ok, thanks! hey I sure appreciate the time you take to help. you specifically have answered most of my posts. thanks again, rowdy
raz ( ) posted Fri, 12 April 2002 at 11:38 PM
ok, another Ques. I did that, and when I dragged all the key frames from 43 to 1 in the animation pallate, the character changed his pose a little. (any idea why?)
Little_Dragon ( ) posted Sat, 13 April 2002 at 12:40 AM
Is frame #43 a key frame? When you do this, I don't think that frame #1 will be overwritten, unless the first frame of your selected sequence (frame #43 in this case) is also a keyframe. You can easily tell which frames are keyframes in the animation palette; they're a brighter shade of green. So if #43 isn't a keyframe, make it one before dragging your selection to the left. Hope that helps!
