Well I got the patch, tried the only .OBJ file I have, SAMS3D park bench(pretty sure that's who it was from, was very cool btw). Anyway, I was able to rotate spin and resize it just fine. Using win XP here. Strange. Maybe you can try getting that file and see if still does it with that one in particular.
'Afternoon Orio . . . 8^) Sorry to hear your having problems. But I too have downloaded & installed the Vue 4.06 incremental patch, & I have imported & edited several .OBJ files, & I have to say that I haven't had one single proglem doing anything with any of the .OBJ files I've imported. I'm running Windows 98SE / PIII 500 / 512 ram. You might consider sending an e-mail direct to Steve at E-on, discribing your problem. Have a good one . . . Mark. ;^)
For yoy Orio and also for Joerg, I have installed Vue "from scratch" on a computer whith Windows Millenium (PIII, 850, 256 RAM) It was a virgin place where Vue never has been. I have done exactly : Vue 4, Vue full update 05, Vue incremential update 06. I have imported all sorts of OBJ files from Poser, free stuff, things I have created outside Vue. All, absolutely all works fine. I can rotate it, move, every thing without problem. Also I think there may be an interference (but I'm not a technician) somewhere on your computer? Now I'm gone to uninstall again, because this computer only has a 10 MB HD, nearly full now. Guitta
I used the incremental patch on my system. It is a windows 2000 system with an AMD Athlon 1700 Chip and 512 MBs of Ram as well as more than 20 GB of empty harddrive space. To describe what is happening exactly: The object does rotate, but it rotates faster and further than it should. It rotates about 1.5 times further than is is supposed to. When the rotation is typed in via keyboard, the object falls apart. The problem seems to be similar to the problem with 3DS-Files we had with the first version of Vue 4. Joerg
Steve, I am unable to properly rotate OBJ objects imported into Vue 4.06 incremental. I can, however, rotate imported 3DS objects. I am running Vue on a Windows Millennium system. - Orio
