Fri, Feb 7, 10:13 PM CST
Forum Moderators: Staff
Subject: I need help please
Greniker ( ) posted Sun, 14 April 2002 at 1:37 PM · edited Fri, 07 February 2025 at 6:53 PM
ok this happens everytime i download clothing for poser
I put it into the library and open poser, when i try to open the clothing to apply it to my character im working on this is what i get
Window 1:The file has a newer version than expected. Poser will atempt to read anyway.
CLICK OK
Window 2:Cannot open resource file..... Whatever i was trying to open
CLICK OK
Window 3:You are out of memory
Please save your work and quit soon, you may also need to increase the ammount of memory allocated to poser.
CLICK OK
so what am i doing wrong, can someone please help me?
KattMan ( ) posted Sun, 14 April 2002 at 4:29 PM
The version isn't a problem. You can get rid of this of you want by editing the CR2 and changing th version number to the version of Poser you have. Now if you are using Poser 3, this may not work out well. The second error is due to your OBJ reference in the CR2. Open the CR2 in a text editor and look at the line that show the path to the figureRes. Go to that directory listed and make sure the OBJ file is there. If it isn't, move it there. The third error is the catch-all message. It is showing up due to the second error
