Sun, Nov 24, 8:41 AM CST
Subject: Egyptian Eyebrows
tshughes ( ) posted Sun, 14 April 2002 at 7:27 PM ยท edited Sun, 24 November 2024 at 8:31 AM
I just bought Anton's Egyptians for DAZ, but the MAT file for Victoria 2 leaves the eyebrows white. Anton's readme for the Egyptians says to make the eyebrows invisible. I've looked but cannot find a way to make them invisible with Victoria 2. It's not a choice in the objects menu no matter where I've looked. What am I missing? Terry Hughes
movida ( ) posted Sun, 14 April 2002 at 9:02 PM
One way is to first select her "head"...go over to the dials on the right side of the interface, scroll down until you find "brows gone" set it to "1.0" Viola!
tshughes ( ) posted Sun, 14 April 2002 at 10:12 PM
I feel like an idiot because I forgot to scroll down. I did as you said, even took the dial to 5.0, but they don't go away completely.
Thanks, this looks beter than what was there.
Terry Hughes
Moonbiter ( ) posted Mon, 15 April 2002 at 12:57 AM
He probably means go into the material editor and turn the transperancy settings up to 100, that will make 'em disappear. Hope that helps.
Fyrene ( ) posted Mon, 15 April 2002 at 1:49 AM
Should never turn the dials to "brows gone". Usually leaves a hole in the head :) As Moonbiter mentioned, use the material editor, select Upper Eyebrows, and set the transparency to 100.
tshughes ( ) posted Mon, 15 April 2002 at 6:03 AM
When I tried setting transparency in the Materials Editor too eyebrows 100% on the Egyptian Woman, the face disappeared but the eyebrows remained. Moving the browsgone to 1.0 makes the face look as it does on the DAZ advertising page, but the brow is not "gone."
Terry Hughes
Fyrene ( ) posted Mon, 15 April 2002 at 11:55 AM
Only the Upper Eyebrows to 100% Terry.
tshughes ( ) posted Tue, 16 April 2002 at 6:05 AM
The Egyptian characters have Anton's own maps. The screen shot has a transparency map for Victoria's. The MAT file from the Egyptian's doesn't place a transparency map. It doesn't have upper eyebrows either, only eyebrows. I'll follow the tutorial link and see what I can learn. Meanwhile, thanks for the responses.
Terry Hughes
