Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 10 9:07 am)
Little Dragon...highlight a wheel and move to a side view...go to window/joint editor and just move the red and green centre markers to the center of the wheels (it helps if you are in outline mode) Thats all it takes...
♠Ω Poser eZine
Ω♠
♠Ω Poser Free Stuff
Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
Ok, I will set this for the rerelease of the 69 Boss 302. The wheels will be able to spin. The 66' GT is still a couple months out. Starting from scratch I have been working on it as a can for about 3 weeks. It is going to be quite high poly so if you don't have at least a P3 1.0 Ghz it may be a problem. The 69' Boss is under 10,000 poly's What is shown above is over 17,000 and still no where near done. Probably going to be in the 50,000 range when completed.
![file_4714.jpg](https://live.cdn.renderosity.com/forum/threads/662278/file_4714.jpg)
For those follow my Classic Car creations. As of lunch today. Original type styled steel wheels and some more on the body done.
