You might try installing the Service Pak 3 and as Ron said your swap file might be to defragged. Under Programs go to Accessories,then System Tools, System Info. You will find out how much memory your system has and how big your current pagefile is mine is 1.96 gig. If you don't see any errors there try switch location of your memory...I had a problem recently that my computer keep telling me I was out of memory even though I had over 512 of ram...I switched memory...and the system is running like a charm.
My life used to be nice and easy, but suddenly, without aparent reason, poser nopw tells m i cant render anything bigger than 800x600 pix... it says theres no enough disk space to render... im working with 15gb freein my slave disk and 12gb in the master, i havent changed anything recently, thats why this is so mistery to me... im working under winxp, but poser didn seemed to have any problem about it... I like to make my renders at 2000x1500, now i cant...anyone can help me??? please????
