Tue, Nov 26, 8:02 AM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: Downloaded Morphing targets
foawashi ( ) posted Wed, 26 January 2000 at 10:44 PM · edited Fri, 22 November 2024 at 12:58 PM
I am new to the forum and love what everyone is doing. I downloaded some of the morph targets to my Mac and tried applying them to body parts (mainly heads) in Poser 4, but they don't show up in the open dialog windows. I can't figure out what isn't working. The only morph I was able to use was one that is a RDS document. The other .obj that just say document just don't show up. Please help me!
Serpent ( ) posted Wed, 26 January 2000 at 10:59 PM
Hello, I don't run a Mac at home but maybe I can answer anyway. The one that says document, is it a obj file ? It has to be a obj file to work as a morph target. It might just be a readme.txt file. Anyway MorphWorld link is on the right side of this page. Near the bottom under Web Resources. Lots of good working morphs there. Hope this helps.
Serpent
MartinC ( ) posted Thu, 27 January 2000 at 2:52 AM
The problem is caused by Poser who only looks for .obj files which are properly typed to TEXT. You can use my Maconverter utility (on FunStuff, Utilities) to type it automatically (it will also convert everything else for you).
rtamesis ( ) posted Fri, 11 February 2000 at 10:20 AM
If you have ResEdit, you should change both the type and creator of the obj file to TEXT, and that should do the trick too.
foawashi ( ) posted Sat, 12 February 2000 at 12:24 PM
Thanks all! MacConverter has fixed the problem and I am off and running/Posing. dpfb
