Sun, Jan 12, 12:47 AM CST
Subject: Searching for an Guy like this ...
tzanh_zsu ( ) posted Fri, 19 April 2002 at 2:40 AM · edited Wed, 25 December 2024 at 9:33 AM
... one right here : [img]http://www.soup-comics.de/public/malgezeigt.jpg[/img] [img]http://www.soup-comics.de/public/fruehegesichtskizze.jpg[/img] [img]http://www.soup-comics.de/public/sehrfrueheskizze.jpg[/img] malgezeigt.jpgfruehegesichtskizze.jpgsehrfrueheskizze.jpg Does anyone know how to make a model like this or how and where to get a model like this?
Seravajan ( ) posted Fri, 19 April 2002 at 4:32 AM
Aha! I see! You are now there too! :) Willkommen an Bord! :) OK. First: Do you have Poser 4? If yes then Try using Michael 2.0 from DAZ3D with BluntCut from the same site to make somewhat like in picture 1 and 2. For Pic 3 you need Victoria from DAZ3D too. The armor have probably to be done in a 3D modelling program. Seravajan
Mazak ( ) posted Fri, 19 April 2002 at 4:46 AM
Attached Link: http://host1.bondware.com/~syydr/catalog.ez?ShowProduct=MM%2D008&ParentID=4
Schau dir mal den Dragonlord von RuntimeDNA an? Mazak
Google+ Bodo Nittel
tzanh_zsu ( ) posted Fri, 19 April 2002 at 5:04 AM
Okay, thanks, but it has to be free, so Mazak your tip is out :( @seravajan: Are they all allready shiped with poser 4? I don't think so. They should be free as mentioned above. Hope there are some further helps for me Tzanh
Seravajan ( ) posted Fri, 19 April 2002 at 5:47 AM
Sorry, no. None of the stuff is free. :( Das vom Kollegen obengenannte Paket ist leider auch nicht frei. :( Aber sehr interessant! :) Man nehme einen Darkelf und steckt ihn in das Kost! :) Seravajan
tzanh_zsu ( ) posted Fri, 19 April 2002 at 7:03 AM
g klar, k gut. Leider komm ich jetzt noch immer nicht weiter. :( Fuck I'm stucked then. I only need an Guy with long Hair like on these Pics up there. Help me ;) Tzanh
Seravajan ( ) posted Fri, 19 April 2002 at 7:20 AM
Hast Du die Free Stuff Sektion durchsucht? Did you searched the free stuff section? Seravajan
tzanh_zsu ( ) posted Fri, 19 April 2002 at 8:05 AM
Yes!!! If not I would not post here ;) Klar, was denkst du denn? ;)
Dmon ( ) posted Fri, 19 April 2002 at 8:05 AM
Get Kozaburos free wavehair and put it on any model you like..
tzanh_zsu ( ) posted Fri, 19 April 2002 at 8:32 AM
Okay, I'll look at this richt now, thanks
tzanh_zsu ( ) posted Fri, 19 April 2002 at 8:37 AM
There are only Textures for it, but not the free Wavehair. Do you know where i can get it?
Dmon ( ) posted Fri, 19 April 2002 at 8:50 AM
Attached Link: http://www.digitalbabes2.com/
When in doubt, always do a Google search :) OK - my fault for not posting the link in the first place... When you apply the hair to male models, you will probably find that its not a perfect fit. Change parent to "Universe" (in "object" menu), then you can move it around as you please. When youve reached the desired result, change parent back to "Head" and you can then pose your figure without the hair falling off :)
MadYuri ( ) posted Fri, 19 April 2002 at 8:54 AM
Attached Link: http://www.3d-cc.com/posergamers/
Hallo. :) The GonbeiHair from digitalbabes has a length morphs too. Also try the posergamers link. Jon Malis are some really good P4 characters with long hair.
tzanh_zsu ( ) posted Fri, 19 April 2002 at 9:08 AM
Thanks a lot, that should work now :) I'll post the Final Pic here, so you al can see it. Tzanh
